Old 10-20-2024, 02:16 PM   #32 (permalink)
Logic
Ever try perfect circle rings with the interlocking second and oil rings? Not a lot of blow by there.
If you get iron based shavings on your magnetic plug after the second oil change, you have massive engine failure in your future.
As I advise dissolving the Boric Acid in hot water and adding it to a hot engine it actually makes no difference to the topic at hand.
From Argonne National Labs who works with the US govt and NASA etc, not some student thesis:
The above results demonstrate that with a mixture of boric acid and an oil lubricant, the friction coefficients are reduced by 10 to over 1000% below those of the unmixed lubricant itself. The wear rates of pins are reduced by factors of 50 to 100 below those of pins tested in unmixed oil itself
https://patents.google.com/patent/US5431830A/en
That's what 1st got my attention and why I studied BA.
Then an old smokey engine came along and I tried it.
That car continued operating for years after till it was stolen.
Now I believe in BA and am trying to share.
Perhaps I should start a new topic:
Looking for 'Old Smokey' (car/engine) for experiment.
aerohead (10-24-2024)
