Old 10-21-2024, 06:15 AM   #35 (permalink)
Logic
What resources do you have? Minimum would be money, a garage, and tools. Eventually you'd need microscopic inspection of the torn down parts.
There's no point in my adding Boric Acid to an engine freebeard.
Someone else has to experience the stuff and report back...
So ye; if someone here happens to have an old smokey engine that they are going to rebuild anyway...
So my question is; what concerns would you/everyone have if you did have an old engine you were about to rebuild anyway and you tried this?
Some microscopic shots of a metal surface with and without BA and the HOW it works:
https://sci-hub.ru/https://www.scien...01679X21000578
The abstract and conclusion, at the very least, are worth a read.
Here's an easy read press release from Argonne National Labs:
https://www.anl.gov/article/nanobori...-more-slippery
Strangely; here I am posting links again because everyone prefers to consider this BS rather than simply do a search for eg:
boric acid in oil lubricant research argonne national labs
So I find myself wondering: What the hell is wrong with people!? Why CHOOSE to live under a rock!??
freebeard (10-21-2024)
