Old 10-22-2024, 02:19 PM   #38 (permalink)
Logic
I'm not a candidate. My Superbeetle has good compression on the other three cylinders, and 70PSI on the first. I doubt the additive would help that situation.
It might, thx to the 0.5 micron thick layer formed.
Thats 2 microns of play gone in a piston-sleeve and whatever the rings are worth.
But ye; if you aren't rebuilding "on Friday" or something...
Do You think I should start a post? Put in all the research links etc?
