Old 10-24-2024, 11:21 AM   #41 (permalink)
aerohead
' piston pin wear '
Originally Posted by Logic View Post
As I advise dissolving the Boric Acid in hot water and adding it to a hot engine it actually makes no difference to the topic at hand.
From Argonne National Labs who works with the US govt and NASA etc, not some student thesis:
The above results demonstrate that with a mixture of boric acid and an oil lubricant, the friction coefficients are reduced by 10 to over 1000% below those of the unmixed lubricant itself. The wear rates of pins are reduced by factors of 50 to 100 below those of pins tested in unmixed oil itself
https://patents.google.com/patent/US5431830A/en
That's what 1st got my attention and why I studied BA.
Then an old smokey engine came along and I tried it.
That car continued operating for years after till it was stolen.
Now I believe in BA and am trying to share.
Perhaps I should start a new topic:
Looking for 'Old Smokey' (car/engine) for experiment.
* Personally, I've never 'seen' piston pin wear, only piston pin, bronze 'bushing' wear, on the small end of connecting rods.
* A 'smoky' engine, suffering from stuck piston rings can, sometimes be 'freed', simply with an oil change, because of the presence of the full detergent additive package within the 'new' motor oil.
