Old 11-13-2024, 03:53 PM   #84 (permalink)
freebeard
Having actually tested it in over a 2 dozen engines; I found I was correct.
Thanks for that. It's a shame popcorn gets stuck in between my teeth.
duckduckgo.com/?q=MotorSilk&ia=web
Was this mentioned upthread?
I have an engine that needs to be torn down due to low compression on one cylinder, and a 0-miles engine assembly on the bench. I assume the first one would warrant treatment after the repair. Would the bench motor need to be broken in before it is eligible?
Logic (11-14-2024)
