I agree that the on-line search is bad. I just stumbled on these bulbs at the larger of the two stores that are in my greater area.
dcwp - The current LED bulb I am playing with from the store is a 12V tracklight bulb! If the track lights you are using right now use the small, 12V bi-pin base, you can swap them right out! (You could even experiment with what your dimmer does to it!)
