Old 11-18-2024, 10:06 AM   #502 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
71 Camaro - '71 Chevy Camaro
White Pearl - '26 Toyota Prius SE
Didn't you have another engine that you were going to assemble and fit to the Camaro, while keeping the Talon? Are you going to daily-drive the Camaro?
You're correct, I do have another engine ready to go in the Camaro. I just recently made the decision to use the Talon engine that is tried and true. The new engine is made more for upper high rpm and will not be as fuel efficient.
The Talon engine in the Camaro should be able to run high 8's in the 1/4 mile pretty easy and should be able to get better fuel milage based on its better aero vs the Talon. Don't get me wrong the Talon has good aero at .29 Cd but the AWD part hurts the Talon a bit.
The main reason I'm getting rid of the Talon it is taking a toll on me trying to work on two highly modified cars. This and I don't have the room for this many projects. The Talon also has drivetrain issues when turned up. Transmission, transfer case, and drive axles are always breaking. Plus, the Camaro will be 100 times easier to work on and make changes on.
The Camaro won't be driven in the winter months but will drive the wheels off it during the warmer months.
Pressure Gradient Force
The Positive Side of the Number Line
