Old 11-19-2024, 07:55 PM   #116 (permalink)
Logic
Not real piston rings but whats interesting here is you can see the blowby in the circumferential movement in the oil between each ring.
Faster between the top and middle ring than between the middle and lower ring.
So I went and looked for research.
Consequence of Blowby Flow and Idling Time on Oil Consumption and Particulate Emissions in Gasoline Engine
1.2l 3cyl 4-stroke Blowby flow measurement for the engine at full load.
rpm l.min−1
1000 31
1500 52
2000 51
2500 52
3000 51
3500 49
4000 49
4500 49
5000 51
5500 49
6000 47
https://www.mdpi.com/1996-1073/15/22/8772
The paper shows it's important to have the ring gaps 180 degrees from each other too.
How long and if they will stay that way I don't know.
Assuming a 0.5 micron thick layer on metal surfaces, you lose 2 microns (0.002 mm) of space between piston and sleeve,
And 0.007mm off the ring gap of the 75mm bore of the engine used above.
I don't think that would make much difference to blowby, but don't know enough on the subject to judge..?
Interesting non the less.
freebeard (11-19-2024)
