Old 11-23-2024, 05:33 PM   #513 (permalink)
Logic
Originally Posted by pgfpro View Post
Here is the test I did on pump 87 vs auto paint waste solvent.
Attachment 35301
This was at a 14.7 stoich A/F ratio. Left side auto paint waste solvent. Right side pump 87 octane. 8-hour burn. Both fuels produced the same amount of heat at the metal test plate.
The right side does seem darker, indication a less complete burn..?:
Ideally HC+O2=H2O +C right?
So theres no getting away from carbon/soot.
Not Ideal combustion is what gives you CO and CO2 gas,reducing C..?
If It's unburned HCs; that's a different story.
Perhaps they stick and get the C to stick?
The mess seen on the upwind side of intake valves seems to bear out this sticky hypothesis.
pgfpro (11-23-2024)
