Old 11-23-2024, 01:24 AM   #511 (permalink)
Originally Posted by Logic View Post
Water mist does nothing for combustion speed, but evaporating water in the intake tracts (Water Injection) does allow for dramatically higher compression without ping, thx to Evaporative Cooling.
That's been in use for ages too.
Greater pressure due to the expansion ratio of steam and a more homogeneous thermal conductivity inside the combustion chamber lead to a cleaner burn. No wonder the times I drove a Diesel in a rainy day the better throttle response felt so noticeable.
Old 11-23-2024, 04:06 PM   #512 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Here is the test I did on pump 87 vs auto paint waste solvent.
This was at a 14.7 stoich A/F ratio. Left side auto paint waste solvent. Right side pump 87 octane. 8-hour burn. Both fuels produced the same amount of heat at the metal test plate.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Logic (11-23-2024)
Old 11-23-2024, 05:33 PM   #513 (permalink)
Attachment 35301
The right side does seem darker, indication a less complete burn..?:
Ideally HC+O2=H2O +C right?
So theres no getting away from carbon/soot.
Not Ideal combustion is what gives you CO and CO2 gas,reducing C..?
If It's unburned HCs; that's a different story.
Perhaps they stick and get the C to stick?
The mess seen on the upwind side of intake valves seems to bear out this sticky hypothesis.
pgfpro (11-23-2024)
Old 11-23-2024, 07:53 PM   #514 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Your chemistry looks good to me but I'm no Chemist lol
As far as a complete burn I really don't know. I'm just glad that this experiment gives me the same results my engine sees.
There is one thing that worries a little bit. My tops of my pistons are so clean it looks like they never have been in an engine. After talking to a Red Bull F1 engineer he said on their hybrid engines today they actually rely on a slight buildup of carbon on top the pistons to act as a barrier coat at maximum power. It will burn most of it off at this point and then at lower power settings it will recoat itself for the next maximum power event. Crazy stuff for sure. Now I might be doing this already when I go from 30:1 A/F to 12.0:1 A/F and I just don't know it.
Old 11-25-2024, 11:48 PM   #515 (permalink)
Definitely crazy. But if you would really need some piston top coating to protect the pistons, wouldn't a ceramic or diamond-look carbon (DLC) coating serve for this very same purpose?
pgfpro (11-26-2024)
Old 11-26-2024, 08:49 AM   #516 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
I think a lot of coatings are prohibited in the F1 coatings rule.
The other thing I should have made clearer is the Honda F1 engine is very unique in the fact that it is almost a GCI engine. The plug starts the ignition process, but the outer perimeter top of the piston ignites mila seconds after.
I have to be very careful in what I write here because I do have some inside information that could get me in trouble. What I can say is some carbon build up is needed at high load with extreme cylinder pressure. The other thing is a Passive Pre-Chamber can increase heat in the cylinder or decrease heat in the cylinder. During light load FE mode, I want to keep the heat in the cylinder due to very lean conditions the combustion temps drop off drastically. The heat helps with keeping the fuel in gas form and I need the exhaust heat to stay up for the hot side of the turbo to work in its optimal area in FE mode. Now in high power mode I need the Pre-Chamber to pull out as much heat as possible.
Old 11-27-2024, 02:28 PM   #517 (permalink)
I can think of a couple of reasons to have a carbon layer on the piston, head, valves.
Not sure if I should or want to talk here now..?
Sounds like you can neither agree nor disagree with what I say anyway!?
pgfpro (11-27-2024)
Old 12-05-2024, 09:24 AM   #518 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Logic, sorry it took so long to reply had to do some lawyer questioning.
At this time all I can say is carbon layer does serve some benefits.
Logic (12-06-2024)
Old 12-05-2024, 09:31 AM   #519 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Took this week off from my day job and got some much-needed personal need to do finished.
Got a question for y'all. Anyone knows of a cost-effective AC self-contained unit that doesn't need a crank driven pump?
Thanks in advance.
Old 12-06-2024, 05:54 AM   #520 (permalink)
Thanks in advance.
IF and only IF:
You live in a dry climate; evaporative cooling is hugely effective and takes zero energy from the engine.
(Extra weight excepted)
AI Overview
The temperature difference, or delta T, for an evaporative cooler in a dry climate can range from 15° to 40°F...
NB
That you need DRY (fresh) air, in which to do the evaporating.
ie: Dry fresh air into the evaporator, into the cabin and OUT of the cabin.
Any humid, water saturated air, recirculating through the cooler, results in a tropical jungle type atmosphere.
(Having been in such jungles in Zaire, Angola, etc I can assure you that you do NOT want that in your car! )
NB The area where the cabin air is is drawn into the cabin (from the high pressure area where the car's hood and windscreen meet)
That intake area already contains drainage plumbing to let rain water out.
So this makes it an ideal place to put one or 2 of these:
NB that its only a "humidifier" if the room is closed...
Edit:
Oops thats the big, multi piezo brick, not one or 2. These:
There's no better large surface area than that mist IMHO and IIRC the piezoelectric bit is very efficient.
I cant speak for the included transformer or anything similar designed to run one off of 12V DC.
All that would be required is a bowl of some sort to hold 1 or 2 of those and an auto top up system consisting of a water level switch, reservoir and pump.
The window washer system might be co opted to act as such with a little bypass switch/valve for when you actually want to wash the window.
I do know that kits were available for sale here some years ago so they are available, but does one need a kit for something this simple?
The Following 2 Users Say Thank You to Logic For This Useful Post:
freebeard (12-06-2024), pgfpro (12-06-2024)
bio fuel, lean burn, turbo compound
