Old 11-29-2024, 07:10 PM   #131 (permalink)
Logic
Originally Posted by vteco View Post
The 6hp water cooled Listeroid diesel noise level is not objectionable. It is a 600 lb chunk of cast iron, with 24" flywheels set in its own shed enclosure, fastened to railroad ties, which are set into gravel on top of heavy sponge rubber horse pad.
It runs at 600 rpm, and the sound is actually soothing -- like a distant steam locomotive A quarter wave would be what... 120 feet in air? No idea in exhaust gas....
We had a similar 2 cylinder Lister in my early years growing up on a farm.
The exhaust muffler was a drum full of screened (6 to 12 mm IIRC) gravel from the 'Diggings' on the farm. (for diamonds by various diggers)
I remember the soothing doef-doef, doef-doef, with fondness.
Yes a resonator pipe would be way too long on those!
Nope, the objectionable noisemaker on the old houseboat was an 80's era Coleman 1200 watt generator, Briggs and Stratton air cooled engine, 3600 rpm, and on a 31 foot boat, you can't get far from that. Impractical to run exhaust pipe underwater. This set up on deck, when in use charging, and had to be stowed in a seaway. Also back pressure wouldn't recommend it, etc, etc.
Now that's where Resonators start making sense.
Our one was used when camping and fishing etc down by the river.
It stood in a hollow/thicket a good distance away and had a piece of rubber? hose that exhausted into the river, about half a foot bellow the waterline IIRC.
There was also some sort of non stock intake filter/silencer contraption that got filled with a bit of old engine oil occasionally.
It probably came off of an old car from the the 40s or something.
(No resonators of any sort that I was aware of)
But the Listeroid at home? I look forward to running it actually. It's fun and most of the house circuits just work, as soon as started and the transfer switches are thrown.
BTW it is hooked to a junk car radiator tilted at an angle high up in my shop adjacent. It heats the shop when the generator is used. Coolant flows hydronically by convection. Air also (no fan needed) through the angled radiator.
I spoke about the simple water heater using the same Lister on the farm here:
https://ecomodder.com/forum/showthre...tml#post695530
I too like simple.
