Old 11-30-2024, 10:59 AM   #35 (permalink)
Logic
To get the most stuff that shouldn't be in the oil out of the oil I found a Baldwin 10 micron hydraulic filter that fits my filter head. Should be grabbing 10 microns at 99% efficiency and have an absolute of 20 micron.
A bt344-s filter.
If you want to filter really small particles out of the oil, the simple trick of sticking a decently strong magnet or 2 on the outside of the oil filter might be worth considering?
It wont do anything for non ferrous aluminum, but will catch the harder ferrous metal worn off of rings, bearings and gears that, being harder, do more damage.
But at the end of the day; a self renewing, chemically inert, layer with 85% the hardness of diamond and the lowest coefficient of friction known to man (in 2007) is what will make your engines outlive you.
https://www.anl.gov/article/nanobori...-more-slippery
But I now get the silence:
Far better to routinely replace engines and buy extra fuel and oil than be a... 'convert', cast out from the herd.
https://ecomodder.com/forum/showthre...-26602-14.html
