Old 12-11-2024, 01:20 AM   #529 (permalink)
cRiPpLe_rOoStEr
Originally Posted by pgfpro View Post
My concerns are with a coating it might change the dynamics of staying clean and could alter the performance. The only way to test it is to coat the pistons and see what happens.
Didn't you have a spare engine which you could use as a testbed? Or enough parts to make some sort of single-cylinder derivative of the 4G63 exactly to use it as a testbed prior to applying some design changes to your project, or maybe discarding some failed designs at a lower cost compared to a regular 4-cyl?
pgfpro (12-11-2024)
