Old 12-11-2024, 10:20 AM   #535 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
71 Camaro - '71 Chevy Camaro
White Pearl - '26 Toyota Prius SE
Originally Posted by Logic View Post
On Copper Plating:
It seems a thin layer is way easier than Electro-plating!
This video was my 1st: "Wait WHAT!??" moment:
They have another: LOL!
Some googling later, here's how it's done:
What I like about this, besides the simplicity, is that it seems to form the thin "porous" layer alluded to in the white paper.
A thick shiny layer of copper, with it's dissimilar coefficient of expansion is likely to flake off of rapidly heating and cooling heads and valves and get itself wedged between piston, rings and sleeve.
I know what you're thinking:
A thin layer like this wont last. It will oxidize off in a matter of minutes.
NOT!!!
See from 3min 27 seconds here:
https://youtu.be/7M5x2OFYP-k?t=207
Ah-ha!!!
Now, while there are a good number of other gasses in a combustion chamber during the power stroke, THAT explains a lot as to why this works/worked so well in the paper doesn't it!!
NB that red hot copper + super heated steam = H2
(It's discovering this kind of thing that gives me a semi! )
WOW!!!!
Damn good fine!!!! Thank You Thank You!!!!!!
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Logic (12-11-2024)
