Old 12-11-2024, 05:56 AM   #531 (permalink)
On Copper Plating:
It seems a thin layer is way easier than Electro-plating!
This video was my 1st: "Wait WHAT!??" moment:
They have another: LOL!
Some googling later, here's how it's done:
What I like about this, besides the simplicity, is that it seems to form the thin "porous" layer alluded to in the white paper.
A thick shiny layer of copper, with it's dissimilar coefficient of expansion is likely to flake off of rapidly heating and cooling heads and valves and get itself wedged between piston, rings and sleeve.
I know what you're thinking:
A thin layer like this wont last. It will oxidize off in a matter of minutes.
NOT!!!
See from 3min 27 seconds here:
https://youtu.be/7M5x2OFYP-k?t=207
Ah-ha!!!
Now, while there are a good number of other gasses in a combustion chamber during the power stroke, THAT explains a lot as to why this works/worked so well in the paper doesn't it!!
NB that red hot copper + super heated steam = H2
(It's discovering this kind of thing that gives me a semi! )
The Following 2 Users Say Thank You to Logic For This Useful Post:
deanznz (04-18-2025), pgfpro (12-11-2024)
Old 12-11-2024, 06:02 AM   #532 (permalink)
Copper:
It goes deeper than that: It's a 'lubricant' that fills wear scars too!?
That means you don't have to stop at plating the head and piston top, you can 'plate' the sleeves too!!!
(You've got to be careful here: Mention bearing surface treatments and some airhead is likely to jump out and demand that it wont work and not to try it!)
pgfpro (12-11-2024)
Old 12-11-2024, 06:25 AM   #533 (permalink)
pgfpro (12-11-2024)
Old 12-11-2024, 08:55 AM   #534 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
71 Camaro - '71 Chevy Camaro
White Pearl - '26 Toyota Prius SE
Didn't you have a spare engine which you could use as a testbed? Or enough parts to make some sort of single-cylinder derivative of the 4G63 exactly to use it as a testbed prior to applying some design changes to your project, or maybe discarding some failed designs at a lower cost compared to a regular 4-cyl?
Yes, I have four back up testing engines now. Two of them are ready to test. The other two are prepping for a new block fill I'm testing for another company.
I'm still trying to figure out how to make a single cylinder engine that wouldn't cost me my bank account. lol One of my concerns after giving it some thought on doing a single cylinder test bed is that the other three missing cylinders effect on pulling the single cylinder through its three "nonpower stroke" cycles.
So, my thoughts are to finish making my run engine test stand and use my engines that are already done and ready to go. It definitely will save on cost. Then there is the thought I could just use the Camaro as the test stand. After doing some simple math I could change out one test piston and rod by myself in about an hour and 45 minutes. I'm leaning this direction because it will give 100% real test results. I keep all the benefits of a true test, Heat generated from the other three cylinders, torsional stress, exhaust mass and pulse widths, and the big one the lack of the power generated from the other three cylinders.
The single cylinder test engine would have helped me in the early stages of piston spray guided testing, but I think I'm past that stage now. My latest test on the Talon "72 mpg" has shown me that there isn't much low hanging fruit left over gains in my design.
There are three major things that are needed with my engines design. First is the static and dynamic compression. Static and dynamic compression I will address later because it's going to open up a can of worms on here with some back lash from people. Exhaust Mass is the third. I need all four cylinders to get the mass needed to make this work. During light load extreme lean burn the exhaust mass drops drastically. I'm running at negative 0.2 psi to a positive 1.0 psi load. This helps with the exhaust mass needed to obtain the positive pressure that's also needed for zero throttle pumping loss and high air lean combustion.
Pressure Gradient Force
The Positive Side of the Number Line
Old 12-11-2024, 09:20 AM   #535 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Originally Posted by Logic View Post
On Copper Plating:
NOT!!!
Ah-ha!!!
WOW!!!!
Damn good fine!!!! Thank You Thank You!!!!!!
The Following User Says Thank You to pgfpro For This Useful Post:
Logic (12-11-2024)
Old 12-11-2024, 10:10 AM   #536 (permalink)
Pleasure pgfpro
I'm still somewhat unsure about 'plating' aluminum though.
Copper Plating Aluminium
Old 12-11-2024, 02:06 PM   #537 (permalink)
Other things; I feel may be worth (building) reputation and money, but I don't have the resources to take them any further.
One also doesn't want to see some unscrupulous person 'own' your idea and take all the credit (and income) for it.
(I do get that an idea is maybe 1% of the effort of commercializing a lucrative a product, but a "Thx to [persons name] who's idea this is based on" at the very least, is just how things should be IMHO)
Copyleft
Technique in copyright law of granting freedoms over copies of a work, and over derivative works by using a share-alike provision
Copyleft is the legal technique of granting certain freedoms over copies of copyrighted works with the requirement that the same rights be preserved in derivative works. In this sense, freedoms refers to the use of the work for any purpose, and the ability to modify, copy, share, and redistribute the work, with or without a fee. Wikipedia
"Sharing is caring" What you're asking for is CC0.
CC0 - Creative Commons
CC0 is a tool to dedicate your work to the public domain, allowing others to use it freely without restriction. Learn how CC0 works, why it is useful, and see examples of organizations and projects that use it.
You can lead a fool to profit, but you can't make him think. --Sandy Munro
Logic (12-11-2024)
Old 12-18-2024, 11:31 PM   #538 (permalink)
It's a common practice in the industry, as I have been told by an engineer who worked at the Brazilian branches of Cummins and Ford.
Maybe it would still be useful for you somehow.
pgfpro (12-19-2024)
Old 12-21-2024, 08:32 AM   #539 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
It's a common practice in the industry, as I have been told by an engineer who worked at the Brazilian branches of Cummins and Ford. I agree it is the only way to build from scratch an engine.
My F1 friend that worked for RB Honda was in charge of the single cylinder group. I learned a ton from him on just the things he could share.
If I get on board with potential engine company, I will use their money to do a single cylinder test engine. The GCI part of my design is in its infancy. I would Love to play with this part by utilizing a single cylinder.
It would It's just a cost thing at this time keeping me from doing this.
Old 01-11-2025, 04:28 PM   #540 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
1/11/2025 UPDATE:
Got the FE modified intake mock upped. This Intake has the N20 system I use for FE to increase flame speed during extreme Lean-Burn 30:1. I'm going to use this during the drive part of Drag and Drive events. Then switch out the intake, injectors and T/B as a whole to the race manifold injectors and large T/B. Also, when I'm daily driving it or street driving during a Drag and Drive event I'll be using the rear 16-gallon pump gas fuel cell.
Also added front vertical bars to the front fenders. After calculating the down force, it had me worried so went ahead and added these bars. Once again, their mocked up and will have grade eight bolts and an added .1875 steel backing plate.
ID:	35436   Click image for larger version
bio fuel, lean burn, turbo compound
