Old 12-24-2024, 03:37 AM   #1392 (permalink)
Logic
The scientific method used in this video is GOOD!?
What's odd is the positive results! (vs the alternator)
Correct me if I'm wrong but intuition says the the area of highest static pressure at the front of a vehicle will be at the most forward, most perpendicular to the wind part of the body where the wind has to change direction the most..? (This is aerodynamics where intuition is almost useless!)
That prop should make it so the air hitting the same surface is no longer perpendicular to it, which may well help..?
I like that this guy gets WELL into the science of things, then does this kind of crazy 'clickbait!?'
https://www.youtube.com/@QuintBUILDs...y=wind%20power
