Old 12-18-2024, 11:46 PM   #1391 (permalink)
Old 12-24-2024, 03:37 AM   #1392 (permalink)
The scientific method used in this video is GOOD!?
What's odd is the positive results! (vs the alternator)
Correct me if I'm wrong but intuition says the the area of highest static pressure at the front of a vehicle will be at the most forward, most perpendicular to the wind part of the body where the wind has to change direction the most..? (This is aerodynamics where intuition is almost useless!)
That prop should make it so the air hitting the same surface is no longer perpendicular to it, which may well help..?
I like that this guy gets WELL into the science of things, then does this kind of crazy 'clickbait!?'
https://www.youtube.com/@QuintBUILDs...y=wind%20power
Old 12-24-2024, 05:21 AM   #1393 (permalink)
The static pressure is highest at the center and fades away forward, according to static pressure heat maps I've seen. Sort of a phantom bull nose riding in front.
He used a windmill forward of the stagnation, if it were closer it would be choked off, might do better further forward.
OTOH an impeller close in could work. So long as it didn't block a radiator.
Youtube's end screen suggests two more videos on the topic from Quint BUILDs.
Old 12-24-2024, 06:39 AM   #1394 (permalink)
I haven't seen any visualizations of the air behind a wind turbine, but it will be slower and less perpendicular after which should help.
But nothing more than an oddity... or is it? See the other (people's) examples 2nd last part of the video.
Old 12-24-2024, 06:51 AM   #1395 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
This is the kind of pedestrian-safe stuff today's cars need!
Old 01-04-2025, 07:34 AM   #1396 (permalink)
I've always liked the Ferrari 250P/250 LM but it's odd I never looked at it aerodynamically and only sculpturally.
https://forums.pelicanparts.com/off-...-pics-884.html
The aft part of the top forming a box cavity buttress reminds me of the sketches I did for a partial cap on my pickup truck. Maybe I had it stuck in the back of my mind after-all.
2016
Roof Spoiler on Pick-Up Truck Cab - Phase-1
https://ecomodder.com/forum/showthre...a-19525-9.html
https://thecarsafe.com/2021/06/17/19...errari-250-lm/
The body work is the result of careful aerodynamic study by Pininfarina.
Ferrari 250 LM
https://www.roadandtrack.com/car-cul...ris-ever-made/
EDIT: Gotta wonder if this one was more aerodynamic and what the actual Cd's were.
https://www.ferrari.com/en-EN/magazi...ne-ferrari-v12
freebeard (01-04-2025)
Old 01-08-2025, 03:03 AM   #1397 (permalink)
What it needs is a proximity sensor that changes it from generator to motor at full power when a pedestrian is detected and machetes for blades!
A recording that yelled: "Pedestrian! Yummy!!" would be nice too!
Old 01-08-2025, 03:13 AM   #1398 (permalink)
https://www.youtube.com/shorts/KvM_nG1u2BA
Old 01-08-2025, 10:35 AM   #1399 (permalink)
Seriously, the pedestrian EV problem is easily rectified by a directional front mounted buzzer/squealer/etc that is activated only while touching the brakes that does NOT sound like an obnoxious horn, but more like normal mechanical operation of an oncoming vehicle, so as not to inspire "pedestrian rage".
The technology certainly exists, just need the will and maybe the foresight?
Same ought to be the case with making the center brake light rapidly flash when making a U turn.
Old 01-09-2025, 07:25 PM   #1400 (permalink)
...that does NOT sound like an obnoxious horn, but more like normal mechanical operation of an oncoming vehicle, so as not to inspire "pedestrian rage".
Why not the opening guitar riff from Sweet Child of Mine?
Piwoslaw (01-10-2025)
