Old 12-24-2024, 06:39 AM   #1394 (permalink)
Logic
The static pressure is highest at the center and fades away forward, according to static pressure heat maps I've seen. Sort of a phantom bull nose riding in front.
He used a windmill forward of the stagnation, if it were closer it would be choked off, might do better further forward.
OTOH an impeller close in could work. So long as it didn't block a radiator.
Youtube's end screen suggests two more videos on the topic from Quint BUILDs.
I haven't seen any visualizations of the air behind a wind turbine, but it will be slower and less perpendicular after which should help.
But nothing more than an oddity... or is it? See the other (people's) examples 2nd last part of the video.
