Old 01-19-2025, 07:56 PM   #64 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
I've been prepping to install the Fit lithium packs in my car, but came across something else - someone selling a Plug-in Prius battery pack for $160 US. The battery is 13 years old and has seen around 75,000 city miles. I decided to give it a chance.
Specs:
Working voltage range 3.0-4.15v
56 cells in series
21.5Ah per cell
0.73kg (1.6lbs) per cell
5c continuous discharge (110 amps)
10c pulse discharge (220 amps for 10 seconds)
7c pulse charge (150 amps for 10 seconds)
Based on this, the pack will support 2.5x the electrical needs of a stock Insight IMA system. The Fit cells would have as well.
The complete pack weighs 80kg or 180lbs. This suggests the cells make up only half the weight of the pack. I expect I'll reconfigure it to 48 cells, which will result in 35kg of cells (77lbs), and I'll remove what I deem unnecessary to make it a bit lighter and more compact. For comparison, the stock Insight battery pack weighs 33kg or 73lbs. You could probably run over this pack with a truck and it wouldn't dent it. Typical Toyota over-engineering.
Pack loaded into the car.
Disassembled for easier removal.
Each module weighs 12.95kg, suggesting the cells make up 80% of the weight of the assembled modules. There is stuff I can pull off these to make them lighter. It'll end up a touch heavier than the original NiMH pack.
The Fit lithium batteries for comparison:
Very promising! My bench power supply measured 20.4Ah into the pack, from 3.0v to 4.2v, suggesting 96% of the original capacity is still available.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
freebeard (01-19-2025), Piotrsko (01-20-2025)
