Old 01-25-2025, 03:31 PM   #302 (permalink)
Logic
Originally Posted by ademonrower View Post
I admire your motivation and ingenuity! I'd been considering doing this kind of thing with a European manual car from the 1970s, i.e. where the technology is very basic, and there's loads of room in the engine compartment! I really like the idea of the e-motor driving the crank pulley via a belt, thereby taking load off the engine directly. I am assuming that your Subaru has automatic transmission. I suspect that that might work better than manual in this situation, but correct me if I'm wrong. I'm basically hoping that manual tramission will be no hindrance to doing a project like this. I'm sorry I don't have advice for YOU, but I don't have a hairswidth of the experience that you do in this area :-/ Thank you!
I do too. It's just all those extra controls I feel would be better integrated with the existing controls.
Combining the throttle with the motor throttle and the brakes with regen should work OK and quite easy.
I haven t read this thread in a while and dont know what your skill and research level is so forgive me if I'm repeating stuff.
NB the the belt pulls on the PULLeys of the ancillaries.
So when the engines crank pulley is pulling on the belt its under tension until after the last ancillary.
After that it would be slack back to the crankshaft if it wasn't for a spring loaded tensioner 'pulley'.
When the pulling is elsewhere on the belt and pulling on the crankshaft pulley, the slack is on the other side... So 2 tensioners are required.
Also look at the mountings of the various ancillaries.
Are they strong enough to handle the extra tension on the belt?
Also NB that this method does not work if the engine is off as you then have to drag the engine along through a whole lot of compression etc strokes.
As you're in Germany your neighbor is likely to have a lathe and milling machine in his garage and do excellent work.
He will be able to build an electric motor into your gearbox before the gearing.
ie: You keep the gearing, allowing you to get away with a cheaper smaller motor, just like the one for your original plan.
This way the engine only drags on the motor when the clutch is engaged and you get to drive with the main engine off and get better/more regen.
The disadvantage is the constantly depressed clutch and constant turning of the clutch release bearing that is likely to wear is out way sooner time wise.
Also the other ancillaries on the engine belt stop working, as does your engine vacuum powered brake assist.
With EVs at the scrapyard nowadays you should be able to find electrically driven replacements for all these.
ademonrower (01-26-2025)
