Old 03-01-2025, 04:35 PM   #7 (permalink)
Xist
The reason I ask is due to this picture:
'Vortex Strakes' in the top row.
I tried to upgrade this, but the Pareto Principal has orders of magnitude:
I thought that a good raster to vector conversion would create infinite resolution, which doesn't do any good here, and vectorizer.io wanted me to pay, but I took a screenshot of the vector version.
It is interesting which parts have good quality and which look worse.
The text looked worse, so I went to redo it.
I couldn't match the font easily.
What the Font said that it is Neue Helvetica Georgian, which it sells for $65, but I downloaded Helvetica Neue from download.com for free.
Times Roman was the official font of the New York Times until they replaced it with Times Roman Georgian in 2007.
Then I realized that Windows Paint does this fun thing where I add text, change the font, write the text, highlight it, change the font again, and no matter what I do, it is always Calibri.
Some people insist it works fine while others say they can't get it to work.
It sounds like some newer licenses no longer come with Paint and there may be a problem when other languages are installed, but I have only had English.
Paint just doesn't allow Center, Right-justified, and Justified, although people insist it used to.
Someone said that you can cut and paste into Word, align it, cut and paste, and it will be aligned in Paint, but that doesn't work for fonts, so I cut and pasted the image into Word.
You can create text boxes and disable the background and border, but you will have good text over bad text.
I didn't see those options, so I set the image to background and lined up text over it.
Then I deleted the text in the image and replaced it in the document.
I didn't worry about the 25% and 30% until I figured out the text boxes, but it removed bits of the diagram in the center and right.
Then I needed to figure out how to convert a Word document into an image.
I am on my laptop... for some reason.
Hey!
Why am I on my laptop?!
This would have been so much easier on my desktop!
I got on here to message my wife.
I don't have Messenger set up on my desktop and plan on replacing the hard drive?
Yes!
I have had problems with Windows, so I figured that I would have a fresh installation on a new 1TB SSD!
When I find the time...
The 512GB SSD I installed in Lappy died before Thanksgiving, so I swapped in the original 128GB SSD, but I still plan on replacing it with the other new 1TB SSD.
I didn't plan on derail the thread, but aside from ignoring all of this and trying to stay in grad school, I would appreciate it if anyone knew more effective ways of doing these things.
I tried different converters and one only cropped the last line of pixels from the text, the rest had the bottom of the text line up with the bottom of the window, so I pretty much lost all of the tails.
I moved the bottom of the frame (a little too far), fixed the last line of each tail, and realized that the background wasn't a single color, there were different shades.
I had really not wanted to try to fix the JPG artifacts, but when the bottom was 4 different shades of tan, I used the magic wand to select the area around the text, around the bottom half of the bottom line of diagrams, and the inside of each letter I noticed.
Hopefully, it cleaned up more of the image, but it took too long to do the bottom 20%, I wasn't doing all of it!
Curses!
I just noticed that it says 30
I didn't fix the 20%, either.
As for vortex generators, I always read they are bandaids for bad aero and short of an expensive computer simulation tested in an even more expensive wind tunnel, there is a 1-in-a-million chance of getting them right.
Would a Prius (or any vehicle) benefit from well-designed VGs on their spoiler?
