Old 03-02-2025, 08:33 AM   #548 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
UPDATE:
Thanks to a few of you here I have finally figure out my home fuel generator.
If SHTF the Talon will be the generator with a very simple wheel hub coupler. While generating electricity it will also be making heat for the house sitting in the garage from the ICE during the winter months and during Summer, I'll move the Talon outside and plug in to the house.
I'm also finishing up a carburetor and points style ignition in case of an EMP. I have a faraday box that has three sets of electronics ECU CAS etc.
I have a bug out spot with stored fuel and supplies that requires an AWD vehicle to get to, with Talon having adjustable coil overs and blizzaks this will be no problem.
Pressure Gradient Force
The Positive Side of the Number Line
