Old 03-06-2025, 05:38 AM   #549 (permalink)
Logic
Originally Posted by pgfpro View Post
UPDATE:
Thanks to a few of you here I have finally figure out my home fuel generator.
If SHTF the Talon will be the generator with a very simple wheel hub coupler. While generating electricity it will also be making heat for the house sitting in the garage from the ICE during the winter months and during Summer, I'll move the Talon outside and plug in to the house.
I'm also finishing up a carburetor and points style ignition in case of an EMP. I have a faraday box that has three sets of electronics ECU CAS etc.
I have a bug out spot with stored fuel and supplies that requires an AWD vehicle to get to, with Talon having adjustable coil overs and blizzaks this will be no problem.
So jack up 1 wheel and attach a generator using the wheel nuts and a flex coupling!?
For people not 'allergic' to spanners; You cant beat that for simplicity!
But your diff's pinion gears, that normally don't rotate much at all (only in corners) will be spinning constantly and fast. That may not be good for diff longevity..?
Then there's the doubling of that one spinning wheel's rpm to consider...
Perhaps an extra pulley on the front of the engine's crank and a ramp/gen doodat:
ie: Pull the car onto the ramp/gen doodat. (with placement indents for the wheels)
Pull the nose down a bit against the suspension with a lever arrangement.
Pop on the belt and release the 'down pull' to tension the belt using the car's suspension.
Now you have electricity without turning the drivetrain = more efficient and less wear-n-tear.
And still an easily moveable ramp/generator contraption.
(Might wear out your release bearing if you want to keep the whole gearbox still. A great place to test out that Boric Acid jiggery-pokery! )
Whats the plan with the exhaust?
Some sort of 'quick coupling' from the exhaust to that flexible metal piping, leading outside?
A thought: (for later)
A couple of coils of that flex tube in a box of sand gives you a sand battery so you can store exhaust heat for later when the engine's off.
As the box is inside the space you want to warm; no insulation required. You could just blow a house fan at/over it if you felt like it.
pgfpro (03-06-2025)
