Old 04-14-2025, 06:50 AM   #17 (permalink)
Logic
Originally Posted by Taylor95 View Post
Well I ended up getting an 05 Golf TDI! It is definitely older than I was wanting but I got a deal too good to pass up!
For highway driving in a cold climate that's a good choice, assuming the engine is good.
As it's mostly highway driving yo can aero mod the hell out of it!
The other thing, as it's diesel, without a throttle valve/flap; perhaps look to the aero inside the induction system:
That would include proper Ram Air design and Bell Mouths and the elimination of sharp turns and sudden sharp edged changes in pipe diameters where all the pipes meet and are clamped together.
People also see benefit from eliminating the screens and grills in the induction system, but one needs to give this a good think:
Air flows way faster in the center of a (induction) pipe than it does at the inner surface.
A screen before a (hot wire) airflow meter averages out the airflow speed just downstream, where the meter is.
Without it the meter will register higher flow and the ECU will add more fuel...
Flow directors in sharp bends excepted; all the other screens and grills are there on the off chance the system ingests something big that may somehow have gotten into the induction system and are unnecessary fuel hogs unless you are liable to leave a nut or something loose in the intake system.
Bell Mouths:
Here the initial Ram Air bell mouth in the/a high pressure area in front of the car will not only give you a tiny bit of increased pressure in the intake but also cut the frontal area of the car slightly.
People think: "Turbo; so this is all BS, but tests have proven otherwise and there are even Bell Mouths just upstream of the turbo impellers of the most successful/efficient turbo implementations.
Both that initial Ram Intake AND the From Filter Box to the Manifold should have a a proper 'elliptical' Bell mouth as there is a dramatic decrease in air (box) volume there.
There are posts here on all the above, as well as the opposite:
Both sucking the exhaust out and filling the vacuum behind the car. (kill 2 birds with one stone)
https://ecomodder.com/forum/showthre...tml#post699835
