View Poll Results: What car should I get?
Toyota Corolla 1 50.00%
VW TDI 1 50.00%
Other 0 0%
Voters: 2. You may not vote on this poll
Old 03-16-2025, 10:01 AM   #11 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Originally Posted by Taylor95 View Post
99% of those miles will be highway miles
An EV really does make sense - what I need might be out of the budget though. It needs to go like 140 miles on a single charge in all seasons. Plus insurance is more on an EV. I'll be living somewhere with solar panels though, so it is pretty tempting.
I do like the idea of a Prius. One just popped up for just over 4k. It's a 2013 in decent shape. 50 mpg is pretty good, and I might be able to get more with various aero mods.
I also spent a lot of time thinking about getting a TDI instead. The major downside of that is that gas is $0.50 cheaper per gallon here. I'm really just looking for something cheap and reliable.
My Nissan Leaf lost more than 50% of range in the winter, and that was one with a heat pump heater, on clean roads, and I was trying my hardest to squeeze as many miles as possible out of it (heater pretty much off most of the time except when I needed to defrost the windshield, very easy on the accelerator, not going at full highway speeds).
Now the Leaf isn't the greatest EV of all time. But I figure anyone wanting an EV where it's cold should get at least double the range they'd need as it will easily be cut in half in the winter.
Old 03-16-2025, 05:36 PM   #12 (permalink)
90 day: 89.66 mpg (US)
EVs make a lot of sense for a lot of people, but long-distance highway travel in extreme weather conditions is probably the least advantageous use-case for them. North America has some of the harshest weather in the world, and some of the longest average travel distances in the world.
Old 03-16-2025, 06:31 PM   #13 (permalink)
90 day: 46.97 mpg (US)
From reading forums, the Bolt in very cold climates loses about 1/3rd range, giving it a worst case range of about 166 miles.
Taylor95 (04-13-2025)
Old 03-17-2025, 11:05 PM   #14 (permalink)
Growin a stash
A Bolt on regular 110V for 500 miles/wk would be tough. Only 4 miles charged per hour. Love Bolts, though. We have 2 of them.
I'll throw the Mitsubishi Mirage out there for your consideration.
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
The Following User Says Thank You to ME_Andy For This Useful Post:
redpoint5 (03-17-2025)
Old 03-17-2025, 11:49 PM   #15 (permalink)
Yeah, gonna need 240v to Bolt that many miles per day, but it can comfortably accommodate those miles.
Old 04-13-2025, 09:39 PM   #16 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
Originally Posted by Piwoslaw View Post
500+ miles per week: Highway? City? Mix?
If mainly highway, then a turbodiesel with good aero.
If city, then a lightweight hybrid would be better. Maybe electric or PHEV, if you'll be doing 2x50 every day with access to charging.
Well I ended up getting an 05 Golf TDI! It is definitely older than I was wanting but I got a deal too good to pass up!
The Following 2 Users Say Thank You to Taylor95 For This Useful Post:
freebeard (04-14-2025), Piwoslaw (04-14-2025)
Old 04-14-2025, 07:50 AM   #17 (permalink)
For highway driving in a cold climate that's a good choice, assuming the engine is good.
As it's mostly highway driving yo can aero mod the hell out of it!
The other thing, as it's diesel, without a throttle valve/flap; perhaps look to the aero inside the induction system:
That would include proper Ram Air design and Bell Mouths and the elimination of sharp turns and sudden sharp edged changes in pipe diameters where all the pipes meet and are clamped together.
People also see benefit from eliminating the screens and grills in the induction system, but one needs to give this a good think:
Air flows way faster in the center of a (induction) pipe than it does at the inner surface.
A screen before a (hot wire) airflow meter averages out the airflow speed just downstream, where the meter is.
Without it the meter will register higher flow and the ECU will add more fuel...
Flow directors in sharp bends excepted; all the other screens and grills are there on the off chance the system ingests something big that may somehow have gotten into the induction system and are unnecessary fuel hogs unless you are liable to leave a nut or something loose in the intake system.
Bell Mouths:
Here the initial Ram Air bell mouth in the/a high pressure area in front of the car will not only give you a tiny bit of increased pressure in the intake but also cut the frontal area of the car slightly.
People think: "Turbo; so this is all BS, but tests have proven otherwise and there are even Bell Mouths just upstream of the turbo impellers of the most successful/efficient turbo implementations.
Both that initial Ram Intake AND the From Filter Box to the Manifold should have a a proper 'elliptical' Bell mouth as there is a dramatic decrease in air (box) volume there.
There are posts here on all the above, as well as the opposite:
Both sucking the exhaust out and filling the vacuum behind the car. (kill 2 birds with one stone)
https://ecomodder.com/forum/showthre...tml#post699835
Old 04-14-2025, 12:45 PM   #18 (permalink)
I'd seriously consider a small, water cooled, 'plug in for winter' genset.
That gives you heat (and efficiency) and some exta amps to save the cold (at startup) battery and some extra range.
There's a lot about 'efficient' small (water cooled) engines hereabouts:
https://endless-sphere.com/sphere/th....118647/page-3
Old 04-16-2025, 10:16 AM   #19 (permalink)
Y2kbug
y2kbug's Avatar
1999 corolla - '99 Toyota Corolla CE
90 day: 39.57 mpg (US)
03 dakota v6 2wd auto - '03 Dodge Dakota
Team Dodge
90 day: 19.18 mpg (US)
regal grandma sport - '96 buick regal gs
90 day: 30.08 mpg (US)
i like my 1999 corolla. Wiring in a Bluetooth radio isn’t difficult. I wired in a 20 something yearold CD player, I had lying around. Not worth a whole lot of money. probably looking to spend less than $3000. I get around 35 miles a gallon and it’s easy to fix. My car I paid $900 for back in december 2023 with 350,000 miles.. I am currently at 388,752 miles.
I drive this car when I’m working. It’s pretty good gas mileage, it doesn’t leave me stranded on the side of the road and if somebody slams their car door into mine it doesn’t ruin my day. I only drive on the eastern half of the United States.
But then my friends that have driven a diesel Volkswagen sedan claim to get 50 something miles a gallon.
back in 2020 I wanted a manual Mitsubishi Mirage. But when I found out how much the insurance was going to charge me, I decided against it.
Old 04-16-2025, 11:14 PM   #20 (permalink)
Older cars are pretty underrated. Don't have to worry about a lot of things - and mine has a lot of life left with only 185k miles on it. Lucky for me it even came with a bluetooth head unit too.
I have yet to calculate mpg on it - my scangauge is not accurate on it.
I am happy with it though - I drove home (65 miles) on a full tank and the fuel needle hasn't even moved.
The Following User Says Thank You to Taylor95 For This Useful Post:
Logic (04-22-2025)
