Originally Posted by Isaac Zachary
My Nissan Leaf lost more than 50% of range in the winter, and that was one with a heat pump heater, on clean roads, and I was trying my hardest to squeeze as many miles as possible out of it (heater pretty much off most of the time except when I needed to defrost the windshield, very easy on the accelerator, not going at full highway speeds).
Now the Leaf isn't the greatest EV of all time. But I figure anyone wanting an EV where it's cold should get at least double the range they'd need as it will easily be cut in half in the winter.
I'd seriously consider a small, water cooled, 'plug in for winter' genset.
That gives you heat (and efficiency) and some exta amps to save the cold (at startup) battery and some extra range.
There's a lot about 'efficient' small (water cooled) engines hereabouts:
https://endless-sphere.com/sphere/th....118647/page-3
