This is also a simple example of some of the clean coal technologies - Often refered to as IGCC or "Integrated Gassification Combined Cycle" Yes i spelled that totally wrong...
Partially burn the coal clean up the by products - then run the "Syn Gas" through a combined cycle gas turbine. Benifits include using coal in a Cleaner Process - you are able to capture much more of the pollutants in the fuel because the initial burn is in a closed system ( instead of the large boiler).
Very neat idea...
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
 First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
