FYI, in addition to lower lift & duration, the Metro XFi cam is also
reportedly advanced, compared to the non-XFi cam (this from the guy who does economy cam grinds):
"6 degrees advanced from the stock cam, based on measurements of intake centerline."
Note the Metro is SOHC.
Everyone who has done the XFi cam swap, myself included, has reported improved low-end torque / driveability, which should contribute to reduced fuel consumption. Impossible to say how much of this is due to valve timing vs. the lift/duration changes.
Coyote X did an (admittedly not perfect)
cam retard/advance experiment and noted these results. He also re-adjusted his ignition advance to maximize it (without ping) after each cam adjustment.
