Old 01-27-2008, 08:52 PM   #11 (permalink)
newtonsfirstlaw
The Mighty Mira - '92 Daihatsu Mira
90 day: 61.32 mpg (US)
Originally Posted by NoCO2 View Post
What kind of tape did you use? If I had to guess I would say it's just clear plastic, packing tape from the pictures, but I just want to be sure before I use it on my car. My car has been in a few accidents by previous owners so there are large gaps that need to be sealed around the head lamps and near the rear fender. I just want to be sure that it will not pull paint or dissolve the clear coat on the paint before I do this because I know some kinds of tape have an acid in them that can damage things such as paper.
The tape is heavy duty construction type plastic tape from a hardware store.
I have not tried to remove the tape, so I don't know what the effects are. If you go ahead with it, assume the worst - that it will strip the paint. I don't know that, but that was my assumption going into it.
The whole reason I could do this was because I have a cheap car and I don't care about resale value. In fact, considering the fuel I'll be saving over driving a standard, unmodified car in a standard way, the payback period is 5 years. If fuel prices go higher in the next 5 years, obviously, the payback period will be shorter. e.g., if they double, it's 2.5 years. If they triple, it's 1.7 years.
"Every body perseveres in its state of being at rest or of moving uniformly straight forward, except insofar as it is compelled to change its state by force impressed." - Isaac Newton
