Old 11-08-2008, 11:27 PM   #6 (permalink)
holypaulie
Originally Posted by Andyman View Post
It's possible that you have a leaking valve, incorrect valve clearance or a worn camshaft lobe. Does the engine run smoothly?
One way to make the gauge steadier is to put a restriction in it. I did that by putting some wire insulation stripped from a wire into the vacuum hose. It has to fit snugly in the hose. Another possibility is to stick a threaded stud or a bolt with the head removed into the hose. It works best if there is a long length of vacuum hose between the restrictor and the gauge.
When I look at the tachometer the needle stay pretty still, but I can feel slight vibration on the steering wheel and floor mat. I'll try the trick with restriction and see what will happen.
