Old 11-13-2008, 04:22 PM   #24 (permalink)
metromizer
Originally Posted by Concrete View Post
let me clarify my position
I'm not able to perfectly "optimize" - no track or dyno....I am looking at simplification of the exhaust
header will remain unchanged and I will keep a muffler
but I'm looking at reducing the long and twisted path of the exhaust
(it is crisping my wiring and rattling loose due to poor geometry)
so this is a very mild exhaust change compared to what your are describing
Can taking half the distance & bends out of a truck length exhaust help?
or is it too complicated to make that call without a dyno
The short answer: If it were me, I wouldn't spend to much of MY effort in just cleaning up bends while replacing an OEM exhaust, a good muffler shop is your best friend with that, those guys work cheap and quick, plus have all the tubing and tools. I suspect you have over the axle routing that looks almost pitched off from the factory bends, a good muffler shop can do a much better job than that if you ask them too. In California the tail pipe needs to exit behind the passenger compartment, at least that was my understanding of the code when trying to get a fix-it ticket signed off for modified exhaust 30 yrs ago. It also my understanding rucks can have the tailpipe exit out he side, just aft the cab. But you want to be careful, if you have a shell on your truck, I have had exhaust gasses find there way under my old Datsun's cap, and seep into the cab via the connector boot between cap and cab in that truck.
The OEM's usually fit the exhaust where they can, it's not always the best. On the other hand my atempts at re-routing always seemed to solve one interference issue but create two more.
