I think the motegi's are about $200 each from Sears... that's including a huge mark-up. You can probably find them used for as little as $400 a set, with decent tires.
Either way, they're still not exactly aero-designed, nor are the Rota slips... in fact, the Rotas are basically cheap rip-offs of JDM wheel designs... that's what the company does lol. There are several companies that copy OEM wheel designs from sportier cars, and make them available for standard, crappy, "why'd you do that?" cars.
I personally would rather have the CRX 13's or 14's, or the HX wheels, which also are not very aero-designed. 13 and 14 inch tires can usually be had very cheaply, if not free, if you don't mind using someone else's take offs. I always get used tires... one of the ways I save money.
Reason: added information
