Will get some aceleration numbers. No more driving until I replace the fuse block. I was very nervous driving the same circuit over and over again thinking I might have a fire down by my feet. I smelled melting plastic after using the turn signal shortly into the drive.
As far as the mileage, there is lots of room for improvement by sorting out the injection and putting in the 3.52 transaxle. I just found out that somebody got 99mpg with the Kubota while testing fuel additive and anti friction compound. This was at 45 mph on a test track.
