Originally Posted by cfg83
uberhho -
I don't think that a single EFIE configuration should be connected to the second 02 sensor because I can *see* the 14.7 ratio with the digital A/F gauge. The second 02 sensor is operating in a different range because I can compare readings when I datalog :
Also, it goes against the logic of what I have read regarding closed-loop operation. What I have read tells me that the *first* 02 sensor is used to determine fuel injection at the stoichiometric ratio of 14.7 to 1.
CarloSW2
If you are getting the magic 14.7:1 then I would see no need to do any more trick f&*$ing my friend. Now my question is are you seeing any improvements, if not why?
