Old 11-18-2008, 10:06 AM   #59 (permalink)
bryn
bryn's Avatar
sputnik - '93 oldsmobile silhouette
90 day: 23.23 mpg (US)
home sweet home - '92 ford clubwagon E-350 xlt
very excelant - '92 honda civic vx
Originally Posted by Christ View Post
The Silhouette is not that bad.. except, again, the hatchback rear config... It could also benefit from a Kammback or boattail with some pretty extreme benefits...
When GM says the Cd is .30, they're not giving you the proper figure... what's the actual frontal area of your nearly 7 foot tall van? When you figure that in, you're not getting that great of a deal.
Swapping a Metro/Swift 3 cylinder into that van could be relatively easy though.
yes i know the difference between cd and cda
so the van is a whopping 5'6" tall, 5'7" wide at its widest (not including mirrors,still counting airspace under car) actual frontal area is pretty close to 30sq ft.
depending on your needs, it is a good shape. do you want to bring 6 friends in your metro, depends on your friends i guess.
i can fit full sheets of plywood inside the van, compaired to a pickup, or stacking them on the roof of a car. aero is going to be much better.
