Old 11-17-2008, 01:24 PM   #51 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
I think the force of drag is (1/2)(Cd)(frontal cross-sectional Area)(fluid Density)(Velocity^2), so Cd is separate from the area in the equation.
Old 11-17-2008, 01:48 PM   #52 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
except when you compare overall drag to complete frontal area of the vehicle, you get a true indication of exactly how aero it is.
You could potentially make something shaped like this
Have a Cd of .40....
Or you could have a shape like this
With a .46, but the second shape is still more aerodynamic, when you compare the Cd to the overall frontal area
That's what I meant when I said that.
Old 11-17-2008, 08:59 PM   #53 (permalink)
But Cd is not the overall drag, it's purely a function of shape. A toy model of your van will still have the same Cd. To get total drag, you multiply the Cd by the cross-section area.
Old 11-17-2008, 09:20 PM   #54 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
simply put its about the amount of air a car needs to push aside and how smoothly is can do so.
a brick is less aerodynamic than an ev1 but it still has less overall drag as its smaller.
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 11-17-2008, 10:12 PM   #55 (permalink)
SO, while I mistyped exactly what I was trying to say, you clearly understood it enough to argue with it.. essentially making less sense.
I'm well aware that Cd is not overall drag, and I'm also aware that CdA is the overall drag figure.
What you've stated here that is not entirely true is that a toy model of a vehicle will have the came Cd as the full-sized vehicle. It will not, even when built to scale, as a direct result of manufacturing inefficiencies.
But I digress, we're taking this off topic.
Old 11-18-2008, 12:16 AM   #56 (permalink)
93 Metro Streamliner
AeroMetro - '93 Geo Metro
Originally Posted by metroschultz View Post
Hey Phil,
I'm thinking take my Metro/Swift engine /trans and put in a stripped out Probe rolling chassis.
I would play the devil getting the weight out (and for the suspension I would not be able to remove weight), but what about the possabilities for aero on something like that?
Schultz
NOOOOOOOO!!!!!!!! Would be very unwise. The Probe weighs over 1000 pounds more. And for the suspension, Metro parts probably weigh half as much.
Makes much more sense to leave the Metro engine in the Metro chassis and do aero mods, such as basjoos and others have done.
Old 11-18-2008, 12:18 AM   #57 (permalink)
Imagine this car with all the wings, mirrors, etc shaved off, and front and rear wheel skirts.
Old 11-18-2008, 12:34 AM   #58 (permalink)
Metroschultz - think of putting 1,000 lbs of bricks in your metro... or 7 average guys. That's what it would feel like still trying to drive that thing. Noone said you had to sacrifice power or speed to get gas mileage. It helps though.
What you'll probably end up doing, is getting further into the pedal trying to accelerate safely (without impeding traffic), and end up getting worse mileage.
Unless you can take about 800 lbs off that car, don't bother.
Old 11-18-2008, 09:06 AM   #59 (permalink)
bryn's Avatar
sputnik - '93 oldsmobile silhouette
90 day: 23.23 mpg (US)
home sweet home - '92 ford clubwagon E-350 xlt
very excelant - '92 honda civic vx
The Silhouette is not that bad.. except, again, the hatchback rear config... It could also benefit from a Kammback or boattail with some pretty extreme benefits...
When GM says the Cd is .30, they're not giving you the proper figure... what's the actual frontal area of your nearly 7 foot tall van? When you figure that in, you're not getting that great of a deal.
Swapping a Metro/Swift 3 cylinder into that van could be relatively easy though.
yes i know the difference between cd and cda
so the van is a whopping 5'6" tall, 5'7" wide at its widest (not including mirrors,still counting airspace under car) actual frontal area is pretty close to 30sq ft.
depending on your needs, it is a good shape. do you want to bring 6 friends in your metro, depends on your friends i guess.
i can fit full sheets of plywood inside the van, compaired to a pickup, or stacking them on the roof of a car. aero is going to be much better.
Old 11-18-2008, 12:37 PM   #60 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Nissan 350z is the closest I see regularly
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Video: clever, simple demo of teardrop shape -pointy end first vs. blunt end first MetroMPG Aerodynamics 12 11-21-2015 04:04 PM
Can I use a GENERATOR to power an Electric car directly? Nerys Fossil Fuel Free 128 10-01-2012 01:24 AM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
