Old 11-21-2008, 08:51 PM   #230 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
A bridge too far.
Originally Posted by Christ View Post
[snip]
Interestingly, no airplane throughout history has ever landed... that is not to say that they don't hit the ground, they just were never designed to "land"... they were designed to fly, so in essence, when they land, they're performing a "systematic, controlled-crash situation"
The idea behind landing a plane, especially to commercial pilots, is to "crash with as little damage as possible".. of course, over time, it's been perfected to the extent that "as little damage as possible" has become almost none.
[snip]
A vehicle that normally used to run on low-grade fuel, but over time, has developed a penchant for high-grade fuel in order to run properly, should be cleaned with seafoam or something similar. (BY the way, seafoam is essentially mineral spirits and kerosene distillates, for those interested, and in general, it is not cheaper to make on your own.)
The reason for this is that something is in the engine (gunk/sludge/coke/carbon/etc) built up on the combustion chamber and piston tops, that is causing higher compression.
[snip]
Just for kicks.... E85 is not 85% ethanol, 15% gasoline.
85% ethanol is correct... the other 15% is "stuff"... lubricants, detergents, cleaning agents, "air scrubbers" etc... there is next to no "gasoline" in E85, except the individual components of it. There are petroleum distillates in it. Other than that, it's nearly purely an aromatic fuel... hence the reason for the additives... aromatics (alone) will lead to bad juju in metal engines.
You've lost credibility.
Sorry.
