Getting .56V on the outer leads. Funny thing is that I'm getting continuity between the wrong leads from the RJ connector. Should there not be 12V getting to the regulator diode? the square one with the heat sink tab? Im getting 12v at the back of the female RJ on the opposite side to the one with continuity to the diode which points to a mistake in the instructions or a crossover phone cord. possible?
It's not the contrast for sure.
How would I rewire the RJ?
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
