Old 11-28-2008, 07:26 PM   #6 (permalink)
msmnick
are you going to try and keep the 50/50 weight ratio :-D
True, space is limited, but the starting weight of around 2200lbs is awesome, and you can strip a miata down to 1900-2000lbs and still have it livable. Obviously the engine goes out and batteries/electric motor goes in, but the weight comes from mostly other areas. The aero could be improved much, too, helping to give you a further range.
