11-13-2008, 01:52 PM
Sharky - '08 Mitsubishi Lancer GTS 90 day: 25 mpg (US) Gusz - '06 BMW 325I 90 day: 24.11 mpg (US)
The Scrap-EV Project
I decided to start a log to monitor my progress with my EV.
The phases are bound to change so I won't get into that until I have my donor car.
I am currently looking at a 1992 Miata convertible 5spd. Only $995. The only issue I see is the small space available for the batteries. Anyone have feedback on that? The hunt will continue until I find the perfect car, I'm in no rush there.
Motors and controllers are important and I plan to actively seek those.
In the mean time I don't like to sit idle, so I plan on putting together what I can. An LED battery monitor, picking up some of the parts like the 12v pump. Also I want to look into powering my lights with it's own independent battery. Because I am in SoCal, I am going to use a solar panel (or attempt to). I just need to research the voltage needed to charge and not just idle the battery.
So here we go - EV #1.
Projects: Scrap-EV - 0% complete ( Website)
11-13-2008, 03:04 PM
Dartmouth 2010
Do it! The miata is a sweet ride,
11-13-2008, 03:08 PM
Pat Beirne's Miata has since been "re-converted" into a bio-diesel range extended EV slash series hybrid: past its all electric range, it can operate at speeds up to 80 km/h / 50 mph on the diesel genset.
You hit the nail on the head re: space for batteries. The answer depends a lot on the system voltage you're aiming for. 90v minimum for a 50 mph car, I'd wager.
Here are a couple more from the album:
Joe Harris' 1996 Mazda Miata
Bill Theeringer's 1990 Mada Miata
11-14-2008, 12:13 AM
EV test pilot
Miata is a great car!
That's one that I considered converting. Space for batteries is the big limiter on that vehicle.
The rear-wheel drive setup is pretty slick for an EV. If I had one of those, I wouldn't have had to shorten my motor to fit it in my car!
Were I doing a Miata conversion, I would use lots of smaller batteries to get the system voltage up, while still having some flexibility in where and how the batteries are mounted.
11-28-2008, 08:26 PM
are you going to try and keep the 50/50 weight ratio :-D
True, space is limited, but the starting weight of around 2200lbs is awesome, and you can strip a miata down to 1900-2000lbs and still have it livable. Obviously the engine goes out and batteries/electric motor goes in, but the weight comes from mostly other areas. The aero could be improved much, too, helping to give you a further range.
11-29-2008, 11:30 AM
EV OR DIESEL
Super sweet!
I've been wanting a miata even for years.
2012 Tesla Model S P85
2013 Nissan LEAF SV totaled by now deceased intoxacated driver.
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
11-30-2008, 08:36 PM
So are you planning on going with the tried-and-true Lead Acid, or do you have the wherewithal for something more exotic?
