Can you get a bigger box wrench on the end of the other to add length? Put the open end through a bigger box and link them together If there's room. Give the base of the o2 a good few whacks with a hammer and chisel or something long and steel. Also try to heat the o2 with a propane torch and get it good and hot then let it cool off. This crushes the rust in the thread.
That's all my tricks.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
