yea... itll be a while before i can get some at the gauge readings. i did test my fuel level sending unit when i was replacing the pump. i read 17 ohms E, 107 ohms F. i did the simple math, and for 1/8th tank its 30.375 ohms. but since im going to replace this with a new unit, ill need it to go by the stock readings. 0 ohms E, 90 ohms F. 1/8th tank is 11.25 ohms.
id like it to come on at that level since this car is probably going to suck the gas down since its a built up "poor mans hotrod"
once a working circuit is made, i could figure a way to wire it into the "blue dinger box" to have an annoying audible sound letting me know im close to E. since all fiero owners hate that sound, the only way to get it to go off is to fill-er-up. having the light would be good too.
