If you punched a large enough hole already, try slipping the head of a bolt through, or something with a good sized lip on it, then using the whole bolt to repeatedly tap it out from the inside.
I hate freeze plugs; I will never pull mine out if I don't have to - I'm using a lower rad. hose heater when I put one in!
Good Luck, Ben!
