Originally Posted by DifferentPointofView
engine is made from different materials that resist corrosion and the electronics do the timing stuff. but you loose a lot of mpg's from using E85. they're built to run on gas, but can run on E 85 or anything between. its pretty much a waste.
I really think that the problem is not enough Ethanol. Instead of E10 they should have Mixtures of E15-E20. Your mileage may very. That's where I have seen the best FE performance.
