I tried the same on an off-ramp last week, and it did indeed restart. What I noticed was a considerable amount of slowdown with turning engine components. I had to restart early (just keyed-on) to maintain a reasonable speed. My process of shifting to neutral seems to work better for me (E-Off, or E-on).
Plus, I prefer having ABS, Airbags, and the SG -- which is all powered down in this scenario. I still have a kill switch in the dash, I just need to rewire it.
The biggest thing to remember with the kill switch is remember you used it! On coast-down (with engines using DFCO), at a pre-determined RPM, the ECU will ask for the injectors to start again -- you may lose TC lockup or experience some interesting side effects, including the need to pop to N and use the starter.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
 _
 _
