Old 12-16-2008, 03:49 PM   #21 (permalink)
Intrigued
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Oldsmobile Intrigue GX
Last 3: 25.94 mpg (US)
Originally Posted by i_am_socket View Post
So I'm reading the other help threads and come across dcb's comment in the Guino KIT thread:
What do I do when both wires have 12 volts (power on, engine off)?
Uh, oh. If that connector is unplugged from the injector, and has 12 volts on both sides, there may be an issue. The computer/module (don't know Toyotas) grounds that ground wire for the length of time in milliseconds that it wants. It's possible there is a 12v feed on the ground side to prevent any fuel from being sprayed when not wanted, however...
I'm wondering now if your voltmeter can't catch the injector ground pulses fast enough to tell the difference. It still could be that you're on the wrong side of the injector...
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Last edited by Intrigued; 12-16-2008 at 03:51 PM.. Reason: Waking up old brain cells...
