Old 12-17-2008, 06:33 PM   #3 (permalink)
TestDrive
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
I've wanted to post some case-studies of some "aero-modded" vehicles for the benefit of members and lurkers whom don't have access to some of the technical press.--------------------- The M-B 111/III knocked my socks off when I read about it, and I was still very impressed with the car when I got to see it first-hand at the Mercedes-Benz museum in 1997.---------------------------------- I can't format the material with tabs,'n such,so please forgive me for the "randomness" of the material.---------------------------------
Playing around with the newly introduced tables in the bb.
The carMercedes-Benz 111/III
Height1,029mm(41.16 inches)
Width1,688mm(67.5 inches)
Length(competition)4,784mm(191.36 inches)
Curb Weight1,347 kg(2,965 pounds)
Power171.58 kW(230-hp)
Final Drive1.65:1
Engine5-cyl TD with intercooler
Chassisall-composite,fiberglass and carbon-fiber
Cd(competition)0.195
Roof slope @ tail11.5-degrees(my measurement)
Maximum cross-sectional area location2,589mm(103.56 inches from nose)
Fineness-Ratio4.64:1
Truncated Boat-Tail Length700mm(28 inches)
PERFORMANCE.
Top Speed @ Nardo Test-Track,Italy315.157 km/h(195.398MPH)-continuous 24-hour driving.
Fuel Economy6.26 km/l(14.7mpg) @ 195.398 mph
(Reformated)
Development of the car included an investigation of a full boat-tail,which added 1500mm length to car and dropped drag to Cd0.178.
A compromise was set at 700mm,which reduced the cars "base-drag" of Cd0.2378 down to Cd0.195 (a 18% drag reduction)
The full boat-tail reduced drag of the base car by 25%.
In full-tail form,the C-111 has a fineness ratio of 6.106:1,which in free-stream,above ground-effect would equate to 3:1,near the ideal teardrop.
Reference: CAR and DRIVER,September,1978,also Dr.Hans Liebold,Research Engineer,M-B,Report,as cited in Hucho,page 142,2nd edition.
Last edited by TestDrive; 12-17-2008 at 07:19 PM.. Reason: reformated table to eliminate padding above table
