Old 02-02-2008, 09:24 PM   #13 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Yeah, I have heard of those before.
My stove is tiny - it barely has room to put wood in it, let alone a water-pipe coil.
It sounds like the best way to go is to wrap a coil of copper pipe around the base of the chimney pipe.
I measured my crawlspace, how many feet of insulation I would need, and the cost.
It looks like for about $900 I could fully insulate my entire crawl-space (think a concrete basement that is only 2-feet deep), using rigid pink foam.
Right now, the crawl space is pretty cold - 55 degrees? That is where all the air for the furnace comes from, and all the air from the cold air returns go to.
If I fully insulate the walls and floor of the crawlspace with 2" of extruded polystyrene, I should be able to have it the same temperature as the rest of the house.
Then I will start saving on my gas bill the rest of my life (or however long we are at this house)
I should also be able to set up some hot water in the crawlspace for my Polish Hydronic System.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
