Old 02-02-2008, 11:21 PM   #15 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I was definatly considering PEX tubing.
As for all the other parts, they get complicated real fast.
I would like to do a system similar to the "Solar heating plan for any home" in the Dec2007/Jan2008 issue of Mother Earth News.
It is an "open" system using a 4000 gallon tank built from 2x4s, plywood, and rubber roofing.
I would use fairly simply thermostats/pump controls for the project. Unfortunately, I would have to use the bronze Taco pump, which costs 2 and half times more than the cast iron one.
The other upside to a simple heat source running to a big box of water to some PEX in the floor is: I could add other heat sources to the design easily - such as a couple solar panels.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
