Old 12-20-2008, 10:04 AM   #18 (permalink)
Funny
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Originally Posted by DieselHybrid View Post
You are correct, the '06 Corolla XRS (which is what I drive) has the exact same Yamaha-designed 2zz-ge engine and the exact same C60 6-speed tranny as the Celica GTS.
I've researched the "easy" swaps ad nauseum. If the Celica/Matrix/Vibe 180 bhp GTS models had had more favorable gearing- I would have swapped for one of those long ago.
So it looks like I need a custom 6th gear? I need something taller than the 0.725 6th gear that comes stock in my C60 tranny.
C64
Gear ratios for this transmission.
1st 2nd 3rd 4th 5th 6th Final
3.166 2.050 1.481 1.166 0.916 0.815 4.529
Applications:
2000-2005 Toyota Celica with the 2ZZ-GE engine
Toyota Corolla Sportivo (Australia)
Toyota Corolla TS (Europe)
Toyota Corolla Compressor (Europe)
2005-2006 Toyota Corolla XRS (USA)
Toyota Corolla Fielder Z Aero Tourer (Japan)
Toyota Corolla Runx Z Aero Tourer (Japan)
2004-2007 Lotus Elise (North America/UK) (mid engine application)
2005-2007 Lotus Exige (US/UK) (mid engine application)
Your transmission has the 0.815 6th gear I believe, you may wish to attempt to find the C60 transmission that I suggested to get the 0.725 6th I am talking about.
If you are dead set on getting a custom sixth gear, try and get into contact with Doug Heffron, creator of the XFi "Areo Car". He made a taller fifth gear for his metro to get 75mpg on the highway. Check out this article for more details.
Hope that clarifies that even further.
Edit: Here is the quote from metrompg.com:
MetroMPG.com: The newspaper article mentions changes to the transmission - can you explain that in a bit more detail?
Doug Heffron: The transmission was the hardest part. 1 found a way to change the 5th gear ratio. I made the gears myself on my lathe. A very proud moment for me. The local machine shops wanted $2,500.00 for 2 gears.
American by right
Ecomodder by choice
Hypermiler by necessity
